1 - 3 of 3 Posts
End of the cruise control saga.
sometimes works sometimes not.
I believe it all started with the snowmobile trailers lights or the connections to it or moisture.
Must of threw a code that prevented it from always working. Never took it in to see what code.
Never found any blown fuses , loose wires or bad switches.
Disconnect your battery for a few minutes, in my case about 1/2 hour and the issue will be gone, that's it , that simple.
Working ever since.
Always check the free stuff first.:thumbsup:
2004 chevy trailblazer_lt_ext
Thats crazy...My cruise would work sometimes and sometimes not....I tow a trailer on the reguar and I noticed that my running lights would not work but the turn sig's work and brake lights ....But for some reason my rear fan stays on sometimes if you lean on the center console so my battery has died for over an hour and after reading what you wrote I noticed that my cruise works just fine hahhaha
1 - 3 of 3 Posts
