1 - 6 of 6 Posts
Mirrors work fine when manually adjusting. When mirrors go into memory settings they start to click and jump. They never go back to where they are set. Anyone else have this problem? Is there a fix?:weird:
I had that problem when they were set to their limit of travel. I reset them in slightly . No more problems.:m2:
Thought it was curbside view doing it at first turned it off, same problem. Will try your suggestion and see if it helps.:thx
when I activate my curbside mirrors they click when they get near the bottom. is that just because it is reaching the limit? can I reset them or change the limit?
I'm not sure about setting the curb assist. There should be something in your owners manual. Page 2-46. It is pre-set. Says nothing about changing settings, only On, Off, or Pass. side only.
The problem with them moving on their own is related to the seat memory and easy exit setting. Turn both of these off and the mirrors will stop wandering on you.
Matt
1 - 6 of 6 Posts
