1 - 6 of 6 Posts
2006 gmc envoy_sle
hey gents just got me another code reader for the obd 2 and plugged it into the envoy today and had 3 codes but no engine light they were P0068 P0106 and P0506. wondering if you guys could tell me what they are.
2006 gmc envoy_sle
ya sorry it did i totaly missed it when i opened it up oops lol. as for the codes
P0068-MAF/MAP sensor throttle position correlation
P0106-MAP/BARO CKT Range/Performance
P0506-Idle Control System RPM Low
Could any of these be set off by my cold air intake?
They can and most likely are due to the CAI, however if you are not current experiencing a check engine light the problem may have taken care of itself. It would seem the codes are just stored in the PCM memory. I would clear the codes with the OBD II Reader and see if they come back after a couple of drive cycles.
P0107 code
Yesterday I took my throttle body off and cleaned it when I put it back on along with the spacer my check engine light came on I ran my ODB meter and gave me this code not sure why my engine light has never come on before checked all parts which werent that much to see if the harness connection and hose was on good it was soo I cleared the codes so far nothing any suggestions.
1 - 6 of 6 Posts
