A while back, I had gotten a some codes while freeway driving and towing my trailer. Mileage was horrible. I tracked it to a vacuum line I didn't connect after having the air box off. I also changed my fuel filter. The codes cleared on their own and haven't come back.
However, my towing mileage still sucks and it labors when getting up to freeway speed. It feels like its got power, but that something is using that power. It will kick into passing go and go fine if I really want it to. Problem is that normally for gradual acceleration I don't have to hit it hard. It dawned on me that it's behaving the same as it would if I had the A/C on while towing. My PS pump has always whined, but has been worse the part few months. At low speeds the steering's a little stiffer.
So, could the failing pump be binding enough to cause what I'm experiencing? I've never had a PS pump go bad, so I have nothing to reference. The problem is really not noticeable when I'm not towing. But even then my mileage is only about 14/15 in mixed driving. Down from 16/17.
