Hello all. First time poster here, located in Ontario. I am no auto mechanic, but I am somewhat familiar with electrical & mechanical.
I have come seeking help on a 2007 TrailBlazer LS 4.2L 4x4. 135000km.
It is showing code P0171 (Lean Bank 1). Long Term Fuel Trim running 10%-28%. Also showed a P0300 once (multiple misfire). Fuel usage is very high. Idling around 900 rpm.
The IAT & MAP seem ok based on readings taken from a cold start. The MAF appears to read properly, but I am not entirely certain where it should read. The upstream O2 sensor also seemed ok, but after scratching my head I changed it, to no avail.
I dumped 1 bottle of good injector cleaner into the tank.
I have a 22" vacuum on the intake, and 60psi fuel pressure at the rail. I cleaned the throttle body following the directions on this site.
Now I'm stumped.
Sometimes I think I hear a a vacuum leak on the drivers side, but I have checked and isolated the crankcase vent hose and the brake booster and hose.
Should I be considering the intake manifold gasket? The manifold itself?
Any help would be greatly appreciated.
TR23
Now I'm stumped.
TR23
