1 - 3 of 3 Posts
gmc envoy_denali
Hi all I have an 06 envoy denali check engine light is on for the vent valve and purge valve,I replaced both wasnt that truck runs fine.I took it i to the shop they are saying its the fuse box and want 1100 to fix I dont have the cash as of now and need to get emissions.How can I get the light off, The scanner wont reset it,Ive uhooked the battery for an hour still nothing I need it off for emissions then Ill get it fixed.Any help would be greatly appreciated
There's no way to fool the PCM into thinking that a detected problem isn't there anymore. The only possible way is to have the PCM tune reprogrammed to ignore the fault, but I doubt you can find someone to do that.
If it's really the fuse box (you need to find out which one, underhood or rear seat) and then find one at a salvage yard.
gmc envoy_denali
Its the under hood box,Havnt found any around here where im at Ive ordered 2 from ebay and both were the wrong ones when shipped to me.I figured as much Thank you for reply
1 - 3 of 3 Posts
