Question:
When I drive and hit little bumbs in the road it sounds like my chassis is about to fall apart. Its getting very annoying and I need some advice. I was going to lube the chassis and try to see if some bushings are bad but i dont have the slightest clue as to where to start looking.
first welcome.fill out you info so we know what you have to better help with diagnosing problem. but sounds like it could be sway bar end links.
common culprits..
sway bar endlinks
sway bar bushings
hood rubber stops
loose spare tire in the rear.
