1 - 10 of 10 Posts
I've got the 2007 4.2L TB with the 3.42 rear end (and front) and recently did a "maiden voyage" towing my 2011 Lance Model 1685 Travel Trailer, which in my case, weighs about 4000-lb loaded. The TB did fine on flats and gentle climbs, but I hit a steep grade on Highway 1 heading toward Lompoc, CA, off of the 101, and the TB wouldn't haul faster than about 35-mph! In second gear. Damn. I'm planning some trips all over the Pacific NW and will certainly hit some serious grades.
So I have options: buy a more powerful V8 vehicle, such as a Suburban, Tahoe, or similar. Or, I am looking into changing out the ring gears on the front (carrier) and rear differentials to the 4.10 ratio. That would give me another 1000-lbs of towing capability, and would keep the engine in the power band going up grades (or so I think).
The gears are not that expensive, and even though I can handle a wrench confidently, I don't have a lift, so would spend a lot of time under the vehicle.
Anyone have any experience doing something like this? (Or just dropping in a used front carrier)
2006 chevy trailblazer_lt_ext
My personal opinion is to purchase a properly equipped vehicle rather than attempt to add capability to an existing vehicle.
I'm definitely leaning in that direction. Too bad the TB didn't meet my expectations.
Yes but keep in mind that it was never marketed as a work-horse, but an outdoors-y type vehicle. It existed in that weird place between the full-size Suburban / K1500 and the not-quite-a-crossover-minivan Uplander.
Discussion Starter #5
Oh, don't get me wrong, it's a great vehicle. It drives really well, it's quiet, powerful, comfortable, roomy, good looking, not too big, and easy (enough) to work on. Unfortunately I put $850 worth of new tires on it before I tried it out for towing and now I'm going to have to sell it. :cry:
2008 chevy trailblazer_lt
We experienced the same thing: a "big" trailer is tough to tow for the L6 motor and 3.42's. I was just in a local junkyard and found an L6 Envoy 4x4 with 4.10 gears, so I took out the rear end. It was a 2002. I wanted to switch rears with my 3.42 rear RWD TrailBlazer, 2008. I later realized the older 2002 rear doesn't have holes and sensors for the ABS near the ends of the axles. I'm also in a dilema like it: try to find a shop that will swap the used gear, or pay for new gear and reflash (expected to be about $1,000+ at a GM dealer), or attempt to DIY the gear swap, or try drilling the old rear, etc. etc. I think the gears may help but it may still be relatively wimpy, especially compared to a 6.0L or 6.2L if you find a Tahoe with a bigger motor. Someone reported it being night and day: towing a camping trailer with a Tahoe 5.3L (white knuckles) vs. a new Silverado 6.2L w/ 3.73's Max Tow package (power and control to spare). Good luck!
Rob in AZ
I meant to mention that I visited the same yard two times, about a year apart, looking for TrailBlazers, etc., with 4.10 gears and only found one. I looked at RPO codes for GT5 on about 25 vehicles and 3.42's came up the most, 3.73's were semi-common but I only found the one with 4.10 gears.
Rob in AZ
2004 gmc envoy_slt_xl
If you're going to swap gears, I would just get a pair of differentials from a junkyard. 3.73s are very common in my area. I recently bought a 05 TB to flip that had a bad rear diff with the 3.42 and was harder to find than the 3.73. I always go to a pull yourself junkyard and the rear was only $100 and they charge $75 for the front.i personally would try that first, that way if it still isn't enough pulling power you don't have much money into it.
2009 gmc envoy_slt
If you change the rear diff/gears, do you also have to change the front diff gears as well so you don't throw off the overall gearing when in 4*4 so the transfer case doesn't have a hissy fit?
Front and rear diffs MUST be the same ratio! Or you'll have more than a hissy fit...you'll have major damage, sooner rather than later.
Honestly, towing that much weight, my advice would be to just get a not only more powerful but heavier vehicle. If your trailer brakes fail (and we all know how reliable trailer brakes are), you could be in serious trouble on a downgrade. 4K unbraked will shove a TB all over the place.
1 - 10 of 10 Posts
