1 - 11 of 11 Posts
I've changed the Oil on my TB 2 times since I got it from a friend, but the Change Oil message does not turn off, It stops after like 10 sec. right after I start the engine, how can I re-set the message, or am I doing something wrong? everything seems to be in order, please help....:worried:by the way I don't have my Owner's manual
simply changing the oil does not make the message go away.
You have to change oil--- and then reset the message.
Once reset the message goes away until its time to change oil again.
Either you reset via the Driver information center...
or
turn key to ACC- within 5 seconds- press the gas pedal all the way down- 3 times--- then you may see the change oil light flash-- it has reset...
On some Trailblazers-- the light doesnt flash- but after the gas pedal press---leave it for about a minute- then you can turn to off position-- and then start the car-- the light should be gone...
some people have to do the reset several times before the light goes away
1 - 11 of 11 Posts
