Oh man! When I read the title, I thought you were talking about your passenger not working (sweetie's side)... I was going to tell you to have her make up for it by keeping her head as far toward the driver's side as possible... I'm not going to go any more graphic than that, but at that point, it's up to you...
Anyway, to the actual problem...
I've had pretty bad luck with GM window switches as the vehicle ages... Having said that, the fact that none of the power stuff in the passenger door works tells you something... I suspect maybe she's got a bad/fatigued power wire somewhere on the passenger side, going to the door...
Find out which pin in the connector is +batter power, and measure it with the key on... If no voltage, try and keep the connectors connected, then jump power to that +B wire in the door connector... If that makes everything work, you've probably got a wiring issue in the vehicle...
Mike
Mike
