1 - 14 of 14 Posts
2007 gmc envoy_sle
I have a 08 Envoy, 4.2, Auto. 4 wheel drive. After i had to have the shop install a new fuel pump, i can not get the tank full of fuel with out the pump kicking off several times. The shop told me it was the vapor canister purge valve. so i replaced that, still no change, no check engine light. I lowered the fuel tank to make sure there was no lines that were kinked, none. Next, i replace the charcoal canister, still no good, still cant pump gas with out taken 30 minutes to get a full tank.I call the shop back up and now they tell me that they dont want to see it back. So what i am i overlooking? All lines are in great shape, all clips are in place and holding good.Thank you for reading this.
2007 gmc envoy_sle
Here is an update... with the lines to the charcoal canister removed, I can pump gas with no issues.
2003 chevy trailblazer_ltz
Does your vehicle have the fuel hose connecting the fill neck to the tank, which has a check-valve in it?
Made all the difference with my '03. Some gas pumps would cause it to "burp" gasoline all over the fender. Others didn't. The vehicle was made to have the check-valve; but GM cheaped-out, failed to include it on at least the early ones.
2007 gmc envoy_sle
Discussion Starter #5
It does have a line from the fill tube that runs down to the top of the fuel tank (not the fill tube) then splits off in a different direction..
After my fuel pump was replaced on my 05 I had this problem. So frustrating it kept clicking off like it was full. It still does it from time to time, usually only when its cold out for whatever reason. Does it more often if I let it get below 1/4 tank. I know it sounds stupid- but my grandpa told me to hold the nozzle from the gas pump sideways when it does that. 9/10 times pumping the gas into it at a different angle holding the nozzle parallel to the ground works. It makes no sense to me why this works. Ancient grandpa wisdom.
2004 GMC Envoy SLT 4.2
Your Gramps has obviously been there and done that .
It's exactly what I found to do the trick on our '04 Envoy .
I believe it has to do with the overflow hose 'placement'.
2007 gmc envoy_sle
Discussion Starter #9
UPDATE------- I now have the fuel tank out of the truck, now a question that sound stupid, If i was to pump air into the "hole" where the fill neck would connect to the tank, and pump air into it, should i be able to feel or hear air coming out of the metal tube coming off the fuel pump?
2008 gmc envoy_sle
your saying if you pump air into the fill neck, there's air escaping through the fuel line off the fuel pump, if so, I believe so yes.
2007 gmc envoy_sle
Discussion Starter #11
When I pump air in the fill neck, I do not get any air out the steel tube that come off the fuel pump.
Also, what is the porpoise of the 2 vents on the top of the tank? A green one on the front and a white one on the rear.
2007 gmc envoy_sle
Discussion Starter #12
Turning the pump nozzle sideways does nothing, still can't pump gas into the tank.
2003 gmc envoy_slt_xl
Had the same problem a couple of years ago on my '03 Envoy XL with the I6 engine. The solution, as Schurkey said above, was to replace the last section of hose that goes into the fuel tank. It is about a foot long and has a flap in the middle of it that only lets the fuel flow in one direction. My original hose did not have a flap. It only had an internal ridge running the the direction of the hose. I replaced the entire fuel filler assembly because I didn't figure out until later that you can just buy the last section of hose by itself.
The part number for just the hose with the flap is 15131046. Be aware that mine is an '03, has the I6, and my Envoy is the XL (extra long) version. Not sure if your '08 with standard wheelbase will use the same hose. Cost was $20 on gmpartsdirect.com.
For anyone replacing the entire fuel filler assembly, I had to take it apart in two sections in order to snake the pieces through the areas they needed to go. The part number for the entire assembly is 88983256 (again, for an '03, I6, extended XL Envoy). Cost was $114 on gmpartsdirect.com, and it comes with the the hose with flap already attached.
2007 gmc envoy_sle
Discussion Starter #14
My issue is now fixed. After removing the tank a few times, something must have moved just enough for it to work. I can pump gas like normal now. I don't know what happened bit it works.
Thank you everyone for putting in your oppinon and thoughts.
1 - 14 of 14 Posts
