1 - 6 of 6 Posts
2007 chevy trailblazer_lt
Hey guys, this is my first post on this great site. I was just wondering if its safe/ and or damaging to tow a Centurion Avalanche c4 wakeboat (i have a 07' trailblazerLT 4x4) . It's dry weight is around 4000lbs and the trailer is another 1000lbs, however when i tow it, it usually has a full tank of gas and is packed with coolers, wakeboards, tubes etc. So I'm thinking it weighs around 5500 - 5600lbs. I've looked into those special trailer hitches that seems to somehow make the load less but will this help? I have a picture of how low the truck sits when the boat is attached but dont know how to post it...
Thanks, Vez
Vez, you are near/at the tow limit. You arent going to want to do that without the proper maintenance/add-ons like a additional trans cooler. (I see that you are in Canada but transmissions will still over heat in colder climates!)
Personally, if I were to do it, I wouldnt go far and stay under 40mph. If a tire were to blow on the boat trailer or something else, that rig would have total control of your truck and the results can be fatal.
Thanks a bunch, I will definitely look into getting one these :)
Discussion Starter #5
Thanks a lot for the help guys but my parents just bought a GMC Yukon Denali, which will definitely be able to pull the boat.:p
2008 isuzu ascender
tow
Much better idea!!!!
1 - 6 of 6 Posts
