1 - 11 of 11 Posts
2002 chevy trailblazer_lt_ext
hello .. i want ask the experts trailvoy members
can i open the headlight by taking the cover out ?
you can try to remove the bulb by squeezing your hand down the back and pop off the rubber moisture cover , or take the grill off and then the whole headlight housing can be lifted out and disconnected , the only tool you will need is a large flathead screwdriver, the grill comes off easy without any tools, if you do a search there is a thread for the grill and headlight housing removal
thank you
yes i want disassembling the headlight housing
its now out of the car
i want take out the plastic cover (Transparent plastic )
there is some clips but it is difficult to remove?!
Me too!
I need to remove the factory low beam covers that are bouncing around inside my light housings.
The only way to take the clear cover off is to cut/grind between the two parts. Those clips were used to hold everything together while the glue hardened.
Northwest Chapter
Only way to do more than remove it or put new high/low/turn bulbs is to cut it open.
Edit: WOOLUF1952 barely beat me to it grrr. :D
One of the benefits of being retired.:raspberry And hiding out when the in-laws come over.
1 - 11 of 11 Posts
