My rainier has 230,000 miles on it and my mechanic says it needs a new front differential, so I'm researching the option to make it a rear wheel drive only. It still runs and drives, but when turning sharp the front wheels get a little angry, hopping and binding. Can someone verify if any of the following options are possible to make it rear wheel drive? There is not option on the AWD to select 2WD.
1. Saw this video on youtube where the guy pulled the front driveline, and took the front axles out. He actually took the u-joints apart and left couplers connected to the inside of the wheels. Unplugged the AWD fuse and claims it is now rear wheel drive.
2. Put in a transfer case from a 2WD/4WD trailblazer and set it for 2WD before installing it, and disengage the front axles by removing the insides? (Not sure if I understood how to disengage the front axles but leave them connected......from the person who suggested this option?
3. Read on a forum (Maybe this one) that one could disconnect the encoder motor and pull the AWD fuse to make it 2WD.
