2007 gmc envoy_denali
I recently got an Envoy denali as my new daily. And I was thinking of replacing the rims, but I actual kind of like the 18 inch they come with.
But basically, upon searching for a decent "all terrain" tire, there was basically nothing for the stock dimensions. However I did find these Hankook Dynapro ATM tires with dimensions of 255/60/r18. So it should be the same, other than 10mm of width.
Is that a small enough amount to be sturdy? I figure since it's the next size up, it might be fine. Anyone with tire knowledge care to help me out?
Just put a set Pirelli Scorpion 255/60/18 on my truck they are extra load tire they fit fine. Also with the extra load you pick up the load rating from 104 to 112 the 255 can handle about 400LBs per tire which will be better for wear. Good Luck
Discussion Starter #4
Hey guys, thanks for the replies! It kind of eases my knowledge knowing I have a little room to play with. The main thing I was worried about was because it was technically a wider tire, but good to know!
