First time poster, although I have used this site a ton since I got my 02 Envoy.
I am having the same problem, as many. After looking at other posts and following the instructions, I have 1.) cleaned the throttle body 2.) changed the oil/filter 3.) installed new cam shaft actuator 4.) installed new cam shaft sensor. I have scanned and reset the SEL every time and the same code keeps popping up. After reading this, I am thinking it may be the wiring. Is there any way I could get further instruction on what wiring to look at and how to test if it is functioning properly? Every time I take off the actuator wiring, it is full of oil, could this be the problem? If I need to, I will replace the wiring if it is not too expensive, I just want the light off and my cruise back.
Any help will be greatly appreciated!
