1 - 3 of 3 Posts
02 trailblazer,4.2 I6... while replacing my waterpump (which is just apin in the arse) i hit the camshaft sensor witha hammer and broke it, bought NEW Sensor code reader said sensor problem..
im unsure if a broke a pin in the connector but someone said i may ned to "FLASH" the ecm for this problem cause i have been running it without the sensor. bad idle and getting worse the more i drive it..
any truth to this?? or does anyone know a way to jump the sensor WITHOUT A scope or a reader???????
2006 buick rainier
Jump what? The ECM needs the signal from the sensor you can't "fake it out".
The sensor is $40. It's broken, replace it. You will not need to "flash" anything.
replaced cam sensor
NOW got p1514 throttle body problem
p0105 map sensor
p0113 iat sensor
p0345 cam actuator solenoid problems
no leaks in manifold,or throttle body or intake.
didnt find a short wire
now wont run.
maybe the PCM went bad, which is not often?
getting a bit overwhelming
1 - 3 of 3 Posts
