1 - 3 of 3 Posts
2004 gmc envoy_sle_xuv
Hello,
Had a SES light, took it to Autozone, they told me it was a Cam Phasing Error. (he didn't give me the code)
Expanation: The ECM has detected the camshaft phase angle has exceeded it's tolerance value.
Probable cause:
1) Loose cam or crank sensor
2) Excessive timing chain free play
3) Blocked oil passage in the camshaft actuator assembly or engine
4) incorrect oil quality or viscosity
I did an oil change already and disconnected the battery for a couple min and rehooked it up and the SES came back in about 15 min of driving.
Any suggestions??
Thanks for any help!
Rob...
Camshaft position sensors have been failing for other members. Run a search, and consider changing it. You might have to pay a dealer to run deeper diagnostics if you want pinpoint accuracy on any SINGLE thing that's the root cause. And even some dealers resort to guessing and shotgunning after a while.
Will a bad cam or crank sensor effect the way the engine runs? Mine seams to run fine, but when I floor it and it's ready to shift in to 2nd gear, it make a funny deep echo sound. any ideals?
1 - 3 of 3 Posts
