1 - 6 of 6 Posts
So my right rear Brake Light & Reverse light won't turn on ......My tail light works fine as do all three other lights including the passenger side rear Brake & Reverse lights. I replaced the entire rear right light fixture & still only my driving tail light works. Any thoughts or advice would be appreciated. Thanks.
Have you replaced the bulbs? If yes, then go to the top of the liftgate and start looking for one or more broken wires in the wire bundle that is inside the rubber hose that goes between the body and the liftgate. That is a known "trouble spot" in TrailBlazers.
plscolla - those wires have nothing to do with the brake and reverse lights. The wires in the rubber boot are for the liftgate items such as power for the LGM, rear wiper and keyless entry.
EnvoyBoy2004, Thanks! Now that I think about it, I see the error of my thought process at the time. Boy was I ever wrong!!!
cdub- I may not be able to help you with your problem specifically but maybe if you use the correct terminology you may have better luck in searching for a fix. You say the right rear doesn't work but you say the passenger rear works. The passenger side is the right side. Driver's side is left side. Hope this helps in your quest.
1 - 6 of 6 Posts
