I’ve been having this issue i haven’t seen anywhere else on the forum where at low speeds and with the brake pedal depressed more than halfway, it begins to stick on the way down but always returns to the top end no problem. only happens when coming to a stop and at 3mph and under. all the wheels spin freely when lifted in the air no lock up. it’s mainly just annoying the truck stops just fine but it can become worrying when you’re trying to stop and it feels like the pedal won’t depress any further but it just needs more pressure to get past whatever is restricting it. at times, and mostly when the front wheels are fully turned to the lock, it will activate abs when the pedal sticks and you’ll hear the crunching noise, and will disengage when the pedal is depressed more.
