1 - 3 of 3 Posts
OK, I've been reading about how prone to failure the ignition switch is and all the problems when it starts to fail. So just wanted a second opinion bout my issue.
About 50% of the time when I turn the key on the warning bells sound real quick and all the gauges and lights cycle. The motor will not start when you turn the key to start. It does nothing have to turn it on and off a few times until everything calms down.
That final turn from on to start on my switch is almost nothing, Normally when you go from on to start it is a decent movement of the key but on mine it's more about applying pressure to the switch than it actually moving to start.
Hope I'm being clear, but as you can see I'm leaning towards a bad ignition. Do you agree?
Thanks,
1 - 3 of 3 Posts
