This is my first post so let me start off by saying hi to everyone. I've been dealing with the dreaded rough idle & the ocassional cutting off. I,ve done a lot of searching on the site and have found a lot of good info. Let me tell ya what I've done and see if I can get any other possible help. Have taken the throttle body off and cleaned it (several times), changed the spark plugs (delco's), changed the #3 coil pack, changed the fuel filter, all were changed with OEM parts. I have even disconnected the coil's one at a time to see if the idle stayed the same or got worse to see if there was another bad coil that had not set a code. Is there another way to test/read them. Any additonal help/thoughts would be greatly appreciated. Like the title says I'm about over it and ready to get rid of it. It's an 04,I6 2wd w/65K on it.
J
J
