You have to have it programmed first, and then have the CASE relearn and possibly the security relearn procedures done before your truck will start up. You may want to read some of the threads under the PCMforLess forum for lots of good info.looking for information on replacing a pcm. like do i have to reprogram the vin right away or have it flashed or can i just hook it up and then start the vehicle?
Mine went completley dead wont start at all trouble shot everything possibleYou have to have it programmed first, and then have the CASE relearn and possibly the security relearn procedures done before your truck will start up. You may want to read some of the threads under the PCMforLess forum for lots of good info.
Are you getting a tune, or did yours just go bad on you?
Why dont you? Get one from PCMforless and have the tune done and slap it in. It will cost the same or maybe even less than getting it from else where. Two birds one stone...Mine went completley dead wont start at all trouble shot everything possible
and you turn the key and nothing the starter wont turn over tested starter relay checked fuses even came on here and asked i did read messages from the very inteligent the roadie and all we could come up with is prolly the pcm
I wish it was just getting tuned :worried:
:iagree: And your truck will run a lot better too! :yes:Why dont you? Get one from PCMforless and have the tune done and slap it in. It will cost the same or maybe even less than getting it from else where. Two birds one stone...
VIN doesnt need to be changed, in our trucks it doesnt matter 2WD v 4WD v AWD, and VIN doesnt have all the options the RPO list does inside the glovebox.I believe you will need to get the VIN changed.
If the new PCM is from a 2wd, it will cause CEL's on your AWD Bravada.
The VIN has all the info on your trucks options. :m2:
Do it, I think they charge $159 for a new/used PCM tuned to your specs plus shipping. Much cheaper than a dealer.Why dont you? Get one from PCMforless and have the tune done and slap it in. It will cost the same or maybe even less than getting it from else where. Two birds one stone...
A good starting point. Should answer a lot of your questions. :yes:When you all say "get a PCM Tune from PCMforless", what do you mean? Do you mean that i can order a new PCM from PCMforless and have them tune it based on my VIN and all I need to do is replace my old one? Or is the PCM Tune an additional component that needs to be installed with my existing PCM?
the PCM is the computer, correct?
with the new PCM from PCMforless, will the performance be that much better?
I ask because I will be cleaning my throttle body tonight after the dealer wants to charge me $700 to replace my computer based on code P0606. If i do need a new computer, I will go through PCMforless, if that is an option.
thanks
What is a CASE?Honestly as long as the PCM is from an 02-05 I6 truck, do the security relearn and have a CASE done (change the VIN if you want) and you're set. Word of caution, if its a PCM with an 04-05 OS then you will get a check engine light as your 02 doesnt have the AIR pump the 04+s do.
Crank Angle Sensor Error relearn. Requires a Tech 2 scantool or equivalent.What is a CASE?
Hellolooking for information on replacing a pcm. like do i have to reprogram the vin right away or have it flashed or can i just hook it up and then start the vehicle?
