2006 Vortec 4200 with 130,000 miles.
I've been smelling Antifreeze emitting from the engine compartment when I exit the Envoy. I had the radiator flushed a month or so ago and it started after that. I decided to stop being lazy and opened the hood today and there seems to be a leak coming from the curved radiator hose where it connects at the radiator and from around the radiator cap. I opened the radiator cap and the Antifreeze is right at the top so that the cap threads, when closed, push the antifreeze up into the hollow section of the cap. Some of the excess antifreeze pushed out when I put the cap back on.
So, does the antifreeze level seem to be high in the radiator? Should I try to remove some of it to lower the level to just below the radiator cap? Could I have a faulty hose or radiator cap that need to be replaced? Is there possibly some other issue?
Thanks,
Jeff
Thanks,
Jeff
