What could cause an alternator go bad so quickly? I have owned my tb since october and i have changed the alternator 3 times. I am going on a fourth one. I dont want to put it in until i know what can cause them to go bad so quickly.
How could there be excessive force on the belt when there is an automatic tensioner? Not to mention the tensioner usually loses tension as it gets older.What failed on the other alternators. If the bearing went, it could be the belt is too tight. Might be just the excess force on it.
Two months per alternator ( even rebuilt ) is unusual IMO.Where are you buying your alternators? What brand? If you get "rebuilt" ones, what you are experiencing is not too unusual.
:iagree: about the belt. That was my first thought also. And more info is needed. Were the previous alternators failed for noise? Or lack of out-put? Or too much out-put? Where did you take them to be tested?The belt for the EXT vehicle is shorter than the SWB, due to a difference in the power steering pump. Maybe some body put an EXT belt on his SWB?
But I agree it's ESSENTIAL we know why the alternators are being changed. If it's for an electrical symptom, it's entirely possible it's being misdiagnosed.
No not unusual. It SHOULD be, but isn't.Two months per alternator ( even rebuilt ) is unusual IMO.
I highly recommend not doing that again. Very bad for sensitive and expensive electronics.I did a test where you unhook the battery while the car is running and if it shuts off then the alternator is bad.
What could the problem be?
I did a test where you unhook the battery while the car is running and if it shuts off then the alternator is bad. It ran for 5 minutes.
