2004 chevy trailblazer_lt_ext
2004 Trailblazer
Just to summarize, I have confirmed all rear lamps work via hazards, reverse, turn signal, and remote entry flash.
Both fuses involved are in tact.
When I depress the brake pedal, I hear a relay under the console near the cigarette lighters, which leads me to believe the brake pedal switch is working.
Short of replacing the relay, should I use a voltmeter to test potential delivery of current to the rear of the vehicle before replacing it?
If there is current, what would be the next step? Thanks!
Oh, and by the way, I'm new here to the forum! :grouphug:
:woohoo:
Over 20 hours and no reply?!?!?
Pretty much what I have found here. I did a little searching and found friends at g m t n a t i o n . c o m. You will receive good direction from friendly enthusiasts. No problems having dual memberships.
Welcome, but go there. You'll be happy you did!
Do you have voltage in the bulb socket?
