When it started to get hotter in Atlanta, I turned the AC on and it blew mostly just warm/ medium temp air. It was slightly cooler than the outside air, but not by much. I added some refrigerant and it didn't seem to really help at first but then after a while it kicked in a little bit. I am now Down in Destin at my friend's condo and had the AC control number 5 work two days ago, and then yesterday it completely stopped working at AC control number 5. After reading several threads I am thinking it may be the Actuator, I am not 100% sure though. I did bring my can of refrigerant down here to the beach with me But I don't want to over fill the resivor and the gauge on the AC recharge does not work. I know that Roadie is an AC expert.. hopefully I can get some of his input on this, as well as anyone else's. I did see some refrigerant that is supposed to seal leaks at Walmart the other day. Figured before I go spend the money on it I would see if these products actually work.
Thanks again everyone,
Brandon
2005 chevy
Did any of the threads you read suggest your blower motor resistor pack could be the cause of losing speed 5? :undecided If you move the temperature sliders, can you hear the driver and passenger side actuators moving or not?
The resistor pack is almost certainly the problem with speed 5.
On the AC coldness, how's the temp of your receiver/dryer? The silver canister on the passenger side of the firewall. If that's not cold, you have a problem on the refrigerant side of the system (compressor, evaporator, condenser). If it's cold and your airflow inside the cabin is not, you have a problem on the temp actuator control side.
I just had my #5 go out the other day. The resistor pack went bad and smoked the harness, so I replaced both. When I pulled out the old resistor (original from factory) all of the metal contacts on the resistor were rusted. You probably need that & you may have an AC leak somewhere. I'd stay away from that AC seal stuff with freon, but that's just me.
The temp of the receiver/dryer is very cold. I would think that it would be freezing me out of the truck.. I wish I had the digital controls and an LT model so I'd be able to see the actual temp inside. But oh well. I had a feeling it was going to be with an actuator control related issue. I just don't know the AC system all that well. How often should I normally need to add refrigerant?
What should my next step be in getting the AC working properly?
I know that there are more posts regarding the actuator, but with the combination of the AC not working very well kind of adds another twist to it.
