1 - 6 of 6 Posts
2006 chevy
2006 Pontiac GTO fans slightly modified with a dremel. Basically, cut height to 28 & 1/4 inches and remove two small mounting tabs on the side of the GTO fans and these puppies cover the whole radiator perfectly! I couldn't be happier! These fans move some serious air! I think I have a new truck, now! I believe I picked up 15hp too? I can't believe what a difference these fans makes. Can't wait for my 4" FWI and a tune. To be continued...
2006 chevy
Discussion Starter #4 (Edited)
Looks great. What did you do with the radiator overflow tank?
Overflow is a $5-$10 bottle from Discount Autoparts. Mounted using included bracket under vehicle factory bolt. The overflow bottle is hidden once everything is put together...
The GTO fan is basically the same size as the SS radiator. I connected the fans directly to the pink accessory wire at the column with a 60 Amp fuse.
2006 chevy
Discussion Starter #6
Thanks! I plan on getting a tune real soon once I create my 4" FWI (parts in the mail) and then I will have the fans controlled by the ECU.
1 - 6 of 6 Posts
