I would like to confirm that the inner bearing on the driver side needs to be replaced.
When I Grab the end of the CV going into it, there is up and down play.
Don't know how much if any is normal or if there should be any play at all.
The hub on this side was recently replaced, reducing the noise.
The other side was replaced last year.
The CV joint is OK, it doesn't knock or leak grease, I don't believe this type of noise is related to the CV correct?
If I drive slowly in a parking lot and put stress on the driver side (hard turn right), I don't feel any vibration. When I bring it up to 40 mph or above I can feel and hear a groan and feel a vibration in the wheel when I turn to the right.
Is this common?
How difficult and costly is it to do DIY
What all should be replaced while its apart assuming it the bearing.
Is it about to self destruct on me?
Thanks!
