1 - 20 of 38 Posts
Anybody with a remote start has a "push button" start. It bypasses the GM security passlock system. Just take a remote start fob and glue it to the dash. :thumbsup:
Just say bye-bye to the vehicle when the crook sees how you start it sometime. :weird:
The only problem with that is remote starts don't let you drive the vehicle without a key. You can start the truck, but once you press the brake pedal it dies if there is no key in the ignition. (That assumes it's installed right of course). Otherwise anyone could break your window when the car was remote started and drive off.
2002 olds bravada
anyone ever notice that our ignition switch is basically like a push start? just flick it in the start position and the engine will crank/start on its own
I never knew that! Thx!! I wouldn't consider putting one in because the weather here doesn't demand it, and I don't want to take the risk of an aftermarket system being able to fail and leave me stranded 40 miles from pavement. But I always wondered how they solved that security issue. :thumbsup:
At one time you could leave a Chevy's ignition unlocked, remove the key, and start and drive the car without a key. You used the key just to lock or unlock the ignition. If I remember the starter button was on the floorboard above the gas pedal, a pedal with a big spring under it.
2002 olds bravada
yeah its amazing how every car starts that way
??? no thats not what i meant. i'm not an idiot. other cars you have to hold in in the start position and wait until the engine cranks and starts. our switches you can just flick it to start and it'll crank on its own.
Joe sarcastic. Sometimes I think he offend himself. Something you have get used to.
Wow, haven't been reading this board long, but I never thought I'd teach you anything...:D There are a couple kill switches on a remote start, one is a hood pin switch that won't remote start the engine if the hood is up (or kills it if it's opened). The brake pedal is another, and if you install one on a car with a manual you're supposed to wire a connection that checks to see the car is in neutral. Otherwise if you remote started a manual that was left it gear it could drive off without anyone in the car... This all assumes it's installed right though, I've read stories of chain electronics stores not bothering with one or more of these.
i know a few vehicles that do that... hell my buddies grand am... if u have it in the off and put it into the on position u can let go and the ignition would turn the key to the run slot and start it self... weirdest thing i ever saw... i never payed attention when he showed me that so i am not sure what he did to do it.. but the key turned past the on to the run and then went back to the on.... :weird:
and as to adding a push button.. unless u add a proximity fob i would not install just a push button... very unsafe...
1 - 20 of 38 Posts
