you have an excessive "air gap" and/or a weak compressor clutch field coil. Very common on this vintage. Remove the shim under the clutch plate or get a new field coil. Field coils are impossible to find so you may have to get a salvage yard compressor and take the field coil off of it. Otherwise you'll need to get a a new compressor and open the system. Than requires evacuation and recharge. Pull the shim out first. Then go from there. HTh c goood
