1 - 9 of 9 Posts
2008 Saab 9-7x 4.2i
I’ve had my Saab 9-7x for about 5 months now, and now that we’re approaching summer, I can’t get my AC to work. The system is charged and the compressor is working, but the clutch will only engage once the engine turns on, and then will disengage after a few seconds. Does anyone know what’s causing this? Thanks!
Super Moderator
2004 GMC Envoy SLT 4.2
Possible rust on the disc . That may have caused too much clearance to the electromagnets .
Check the clearance between the disc and the electromagnets . I believe that should be .013" - .032" .
If it's toward the outer limit , pull the front of the clutch off ( held by a single center bolt ) and clean the face of the disc as best you can .
It should be fairly smooth . While the disc is off check for shims on the shaft to allow a tighter clearance and better performance .
Note that it's pretty tight working , but , I did the job with no special tools .
My clutch clearance was .032" and would sometimes catch , but mostly not .
I pulled and cleaned the disc and removed a shim to bring the clearance down to the lower limit : .013" .
The AC hasn't skipped a beat since .
Super Moderator
Don't worry about rust if it engages at all, just reduce the clearance.
That^ is ridiculous . If there's rust , remove it if possible as it will only get worse . That means it will thicken and what do you know , that's exactly what you want to avoid .
Super Moderator
That ^ is ridiculous. If it engages, there won't be any substantial rust on the pulley face or the hub.
That's not at all what I found on our clutch . there was plenty of rust and it would only engage occasionally .
Like anything else , get rid of the rust .
What you're saying is tantamount to : if there is corrosion on an electrical connection and it still conducts once in a while , leave it dirty . What kind of logic is that ?
How lazy can you get ?
Really??? This is a clearance problem, not an electrical problem. Where I work we reset the air gap on A/C compressors all the time, whereas other shops will replace them, costing the customer way more. Get real... Rust is not the issue.
Super Moderator
At least with replacement the unit might have a much longer work life than doing a partial job .
Pay for what you get .
I never said it was electrical or that rust was the issue .
I said : If rust is there get rid of it , if possible .
Why not do as much as possible to avoid having to do a job twice ?
2003 chevy trailblazer_ltz
If the A/C compressor clutch engages reliably, the friction of partial engagement will clean the rust without having to diick with it. The natural rusting--and removal of that rust--probably accounts for the growth in the clutch gap.
If an A/C compressor engaged, then disengaged soon after...I'd be expecting a low refrigerant charge.
1 - 9 of 9 Posts
