AC aluminum evaporator tube torque spec?
379 Views 8 Replies 5 Participants Last post by  SR3000
Does anyone know the torque spec for the circled nuts on a 2002?
1 - 9 of 9 Posts
1-Attsa 'Bout Right.
  • Like
Reactions: 1
I usually would but I'm trying to eliminate issues.
I think 2 to 3 ugga duggas is more than enough, especially on those smaller nuts.
In all seriousness, I have a Haynes manual at home with torque specs. They might have it. If you're not in a rush I can check it when I get home tonight, after 6pm EDT.
That would be fantastic if you wouldn't mind. The gaskets won't be here until Friday.
I don't mind at all. If someone beats me to it, so be it. I'll have numbers tonight as long as the book lists them.
  • Like
Reactions: 1
Actually, anything beyond finger tight is just for anti-rattle conditions, since o-rings are not dependant upon the flange bolts for their sealing integrity anway. Agonizing over trivial things here is not worth the time nor troubles.
BUT the first windmill to jab is to start by using a 1/4" drive ratchet and the correct 6-pointed sockets, use common sense and - adjudicating for some feel - snug is just as good as finger tight - like I said.
However, in a quest to keep ex-NASA engineers from popping up like a bunch of Prairie Dogs and to keep them in their own cubicles until their end-of-shift, the self-aggrandizement specs for most GM A/C Aluminum lines at-of-near-around compressor and assorted fittings, follow the (er) 'following' --- using a freshly calibrated and lubricated with GM Spec Lubricant (GTWL-002.212 j/s) for an Inch/Lb non-torsion bar type torque wrench (GWR-33.01/rev.d) :
Torque the hose assembly at rear of compressor, using new sealing washers.
Nut and/or Bolt to 33 N.M (24 lb. Ft.).​
Tiighten the line to condenser with mounting bolt.
Nut and/or bolt to 16 N.M (11 lb. Ft.).​
Line at accumulator with mounting bolt.
Nut to 16 N.M (11 lb. Ft.).​
This information brought to you by:​
The Official GM Fastener/Torque Wrench Developement Crew
  • Haha
Reactions: 3
Nut 28 N·m - 21 lb ft
  • Like
Reactions: 1
I'd like to say he's in rare form, but no, he's not 😉
1 - 9 of 9 Posts
