1 - 15 of 15 Posts
i have an 06 trailblazer ls. about a month ago my abs and traction control light started coming on and off. now they pretty much stay on. the code came up as right rear wheel speed sensor so i changed it and it is still throwing the codes and lights came back on......please help. thanks:confused:
C0050. code for wheel speed sensor. just replaced it yesterday. today i noticed the lights would flash from time to time and eventually went off until i stopped the truck. after i turned it off and restarted it only the trac control and svc trac lights were on. abs light would only come on at a complete stop.
2002 chevy
i have the same problem. i thought mine had something to do with the tune dealing with the speedometer...claiming that its incorrect. still working on it like you
2007 chevy trailblazer_lt
I am also having the same problem since two weeks,roadie you can really give us the solution for this problem.
Thank you
Yesterday i too my TB to stealership and asked them to diagnosis my problem they said it will take atleast 12 days and after they find the fault it will take another 10 days to repair as they are loaded,so i just took my vehicle to one of the private workshop they diognosed and found out that one of the left front speed sensor has to be replaced.
i will replace it probly tomm and see what will be the status.
#03-05-25-007D: Antilock Brake (ABS) Activation at Low Speeds (Clean Wheel Speed Sensor
Mounting Surface) - (May 1, 2009)
Subject: Antilock Brake (ABS) Activation At Low Speeds (Clean Wheel Speed
Sensor Mounting Surface)
Models: 2002-2006 Cadillac Escalade, Escalade EXT
2003-2006 Cadillac Escalade ESV
1999-2006 Chevrolet Silverado
2001-2006 Chevrolet Suburban, Tahoe
2002-2006 Chevrolet Avalanche
2003-2006 Chevrolet Express
2007 Chevrolet Silverado Classic
1999-2006 GMC Sierra
2001-2006 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2003-2006 GMC Savana
2007 GMC Sierra Classic
2003-2006 HUMMER H2
This bulletin is being revised to add the 2007 Silverado/Sierra Classic models. Please discard
Corporate Bulletin Number 03-05-25-007C (Section 05 -- Brakes).
Condition
Some customers may comment on ABS activation at low speeds, usually below 8 km/h (5 mph). Upon
investigation, the technician will find no DTCs set.
Cause
The cause of this condition may be an increased air gap between the wheel speed sensor and the hub
reluctor ring due to rust and debris built up on the sensor mounting surface.
Correction
Measure AC voltage and clean the wheel speed sensor mounting surfaces.
1. Raise and support the vehicle.
2. Disconnect both the front wheel speed sensor connectors at the frame and harness.
3. Place a Digital Volt Meter (DVM) across the terminals of each wheel speed sensor connector.
4. Rotate the wheel clockwise approximately one revolution per second. The minimum reading
should be at least 350 ACmV's. If the reading is less than 350 ACmV's, remove the wheel speed
sensor.
5. Plug the wheel speed sensor bore in order to prevent debris from falling into the hub during
service.
6. Clean the wheel speed sensor mounting surface using a wire brush, sand paper, emery cloth,
scotch brite, or other suitable material. Be sure to thoroughly clean the wheel speed sensor
surface. There should be no rust or corrosion.
7. Check the sensor head to determine if it has been warped/distorted due to the corrosion build up
or other causes. Check the mounting surface on the sensor head for flatness by placing it on the
edge of a metal machinists scale or other suitable straight edge to measure the flatness. Check
the sensor for flatness in multiple (minimum 3) positions/directions. If the sensor head is
distorted, replace the sensor.
8. Apply (spray) two thin coats of the specified rust penetrating lubricant (corrosion inhibitor) to
the complete sensor mounting surface on the bearing hub. Allow to dry for 3-5 minutes between
coats. Use ONLY Rust Penetrating Lubricant, P/N 89022217 (in Canada, P/N 89022218).
9. When the corrosion inhibitor is dry to the touch (about 10 minutes), apply a thin layer of
bearing grease to the hub surface and sensor O-ring prior to sensor installation. Use ONLY
Wheel Bearing Lubricant, P/N 01051344 (in Canada, P/N 993037).
10.Install either the original sensor or a new one in the hub. Ensure that the sensor is seated flush
against the hub. Refer to the applicable Wheel Speed Sensor Replacement procedure in the ABS
sub-section of the Service Manual.
11.Place the DVM across the sensor terminals and recheck the voltage while rotating the wheel.
The voltage should now read at least 350 ACmV's.
Parts Information
Part Number Description Qty
89022217
(Canadian P/N 89022218)
(Package of 2 cans)
(Each can will service 50+ vehicles)
1
01051344
(Canadian P/N 993037)
(Package of 12 tubs)
Wheel Bearing Lubrication - Tub
(Each tub will service 25+ vehicles)
Discussion Starter #9
abs,trac control,stabiltrak problems still
i have replaced the right rear wheel speed sensor again as the code reads, i have also replaced the left rear and the speed sensor in transmission. still have same code and lights came right back on after clearing them once i reached about 8 mph. also, i now have code running lean in bank one. any and all help is appreciated.:bonk:
Discussion Starter #10
its been a while and i am still having issues. abs, traction control and service stabilitrak lights still on solidly. i have done major reading and have changed and done just about everything except for cluster. any more advice? :confused:
Abs etc.
Has anyone got a response to the last post on this
I also have ABS< Traction control etc. I was running around for a couple of months with the ABS fuse pulled because of low speed engagement.
Then had front hubs done. Now have the lights on dash.
Any suggestions?
Thanx
2008 chevy trailblazer_lt
Hi My abs and traction control light as well as the fix tc all come on on first drive. If I stop and turn off engine for less than 10 minutes eg get gas , then restart no more trouble leds.!! Also my scanner shows no error codes whatsoever??? Can the ignition switch cause this ?
2003 chevy trailblazer_ltz
Now front wheels not turning. Wondering clutch fan ?
The front brakes are locked up??? What would the fan clutch have to do with that?
Never mind the codes. Use the scan tool to look at the data stream, see what speeds the speed sensors at each wheel are reporting. They should all be the same, and the same speed that the speedometer is showing.
Thanks I checked the blue driver site ...
The scanner for 2008 tb only supports the following live stream data because the tb does not stream live abs data unfortunately, according to their web site. Unless one of these is abs data?
Live Data:
  • Fuel system status
  • Calculated LOAD Value
  • Engine Coolant Temperature
  • Short Term Fuel Trim - Bank 1 / Bank 3
  • Long Term Fuel Trim - Bank 1 / Bank 3
  • Short Term Fuel Trim - Bank 2 / Bank 4
  • Long Term Fuel Trim - Bank 2 / Bank 4
  • Intake Manifold Absolute Pressure
  • Engine RPM
  • Vehicle Speed Sensor
  • Ignition Timing Advance for #1 Cylinder
  • Intake Air Temperature
  • Air Flow Rate from Mass Air Flow Sensor
  • Absolute Throttle Position
  • Bank 1 - Sensor 1
  • Bank 1 - Sensor 2
  • Bank 2 - Sensor 1 / Bank 3 - Sensor 1
  • Bank 2 - Sensor 2 / Bank 3 - Sensor 2
  • Time Since Engine Start
  • Distance Traveled While MIL is Activated
  • Commanded Evaporative Purge
  • Fuel Level Input
  • Number of warm-ups since DTCs cleared
  • Distance traveled since DTCs cleared
  • Evap System Vapor Pressure
  • Barometric Pressure
  • Catalyst Temperature Bank 1, Sensor 1
  • Catalyst Temperature Bank 2, Sensor 1
  • Control module voltage
  • Absolute Load Value
  • Fuel/Air Commanded Equivalence Ratio
  • Relative Throttle Position
  • Ambient air temperature
  • Absolute Throttle Position B
  • Accelerator Pedal Position D
  • Accelerator Pedal Position E
  • Commanded Throttle Actuator Control
looks like abs live data is not there ..........eck
1 - 15 of 15 Posts
