1 - 3 of 3 Posts
I have a 2003 GMC Envoy XL and recently my ABS comes on at every stop but there is no dash light.... Anybody had this problem....
Usually this is caused by a weak front wheel speed sensor or a build up of rust and corrosion under the speed sensor mounting plate. Inspect the area around under under the sensor mount, and clean if necessary. A high-end scan tool can tell you which sensor is the problem.
Thank You.... I will check for a high end scan tool just to be sure which one needs cleaning or replacing...
1 - 3 of 3 Posts
