Hi all, like the title says I am planning to replace the Door Mode Actuator on our new to us 2003 Envoy XL SLT with the dual climate controls. I actually found this site when our mechanic said it was a $500+ job to remove the entire dash and replace the part..yikes.
I sourced most of my info from these two threads (linked below) which seem to be fairly comprehensive. In our vehicle: all air vents seem to work properly and dispense air as expected. I do however get the clicking noise only when the Mode switch is in the floor or floor/defrost mode. In addition, the Driver knob on the control module does the inconsistent number climb mentioned in a few threads here as well. I assume the two could be related?
So, despite everything actually working, I would like to end the clicking noise and replace the Control Module (since it is also has a few lights out and signs of wear.) Any and all advice on this process is greatly appreciated!:thx
Replacement parts:
-AC Delco Part #15-73599
-Dorman A/C Control Module Part #599-211
Sourced Threads: (not enough posts for links)
The sticky under 02-09 "Hot-to" by 03Huggy
and
"Mode Actuator Replacement 2006 Trailblazer" by dmtaurus
Replacement parts:
and
