1 - 3 of 3 Posts
Recently I have started losing a lot of oil, about a quart every 100 miles or so. It seems to be coming out of the resonator and spreading all over the valve cover. At first I thought it was a blown gasket on the passenger side of the engine because of the smoke coming from there, but then I saw that the oil was dripping onto the exhaust manifold and I think that is what is causing the smoke. Also, when idling sometimes white smoke will puff out of the air filter box - not constant, but it does do it every time I idle. So long as the engine is full of oil it runs fine - smooth and powerful. It is not overheating and there is no coolant leak. There doesn't seem to be any smoke coming out of the exhaust either.
The best I can tell the oil seems to be coming out of the bottom of the little bent tube connected to the underside of the resonator. I cleaned my throttle body according to the procedures on this site about 3 months ago, but this problem didn't start up until about 2 weeks ago right after I changed my oil and oil filter.
Does anybody know what could be causing this?
how much oil did you put in?
what filter did you use?
what oil weight did you put in?
1 - 3 of 3 Posts
