Yup! Those are the symptoms of just a clutch. Some others include: works fine on startup, and shuts off and starts blowing hot air after driving a bit (like someone else said, once even more heat has built inside the engine compartment from driving for a while, internal resistance in the magnetic clutch rises, and then either a fuse or some intelligent circuit breaker flips), and of course, frequently blown fuses-- but the a/c works great in between replacing fuses. Sure signs of an electrical issue, and not the compressor itself at all.
A clutch is cheaper too, because there's no a/c evacuation and recharge, and depending on the car, the clutch can be done right on the compressor without pulling the compressor, so it's faster also.
As far as gap being too large, feeler gauges work great, and if you can see your compressor, you can watch it engage when a friend inside the car turns on the a/c-- or not engage, if the gap is way too large!
Yeah, dealership parts do end up being expensive, just being a retail outfit.
They buy from GM for $250 and then resell for $500 (just making up those numbers)-- where you can just buy online yourself for the $250, or less ;-)
But, they've got a supply chain, warehouse, shipping costs to cover, not to mention some insurance in case the new part comes in bad and they need to pay the mechanic all over again to reinstall. Not often, but it happens, so dealership prices have to cover the % of comebacks also.
I don't know about a/c compressors, but people do try to save a buck (or a couple thousand of bucks) by buying junkyard engines or transmissions, or a rebuild from the cheapest source they could find.
These things DO have a nonsurprising chance of a comeback, and the labor costs to redo them are expensive, when someone brings their own rebuilt or junkyard transmission, pays $1000+ to have it installed, and it starts slipping next month.
A friend at an independent shop went through 3 transmissions on a hummer when the customer brought in a rebuild he ordered online. First was slipping from the getgo, uninstall, ship the core back to CA and get another rebuild under warranty, pay for the labor all over again, same thing but after a week this time, ship the core back... wait for another rebuild... it's been a year now, I might ask if the 3rd time's been the charm. But it cost him 3 R&Rs because of the shoddy trans supplier.
If it had been the shop's own supplier, the shop would have been eating the pay for the mechanic twice over.
So it's also built in insurance and CYA when a dealership insists on only offering branded parts and their own in-house $5000 rebuilt transmissions. If a sleazy dealership started offering junkyard transmissions for budget-minded drivers, they'd lose their shirts on the comebacks. I know some junkyards even offer lifetime warranties on such components, but it would only cover the part with another salvage, and none of the significant labor charges.
Again, haven't done too many ac compressors (and failure rates on cheap ebay ones, which might not be bad, I dunno!), but another example is when I bought a $25 power lock actuator on ebay, made in china of course, thinking I saved a bundle over the $150 the oem version cost. Whaddaya know, it doesn't work. No power, can't pull the lock all the way down when unlocked, can't pull the lock quite all the way up if locked. Freezes solid when colder than 40F, and barely works in this summer heat. I did finally find some oem overstock on ebay, selling below cost I'm sure.
Can you really fault a dealership for charging $160, for a part that works?
If they offered people the option of the $25 (marked up to $50) door lock actuator, they'd be eating a LOT of comebacks; and the labor I'm sure is $100-$200 a door. And if I weren't doing it myself and eating my own labor time as it is, if I'd brought that $25 lock motor (x3 doors, actually) to a shop and had them install them, I'd be out $400++ in labor costs because of my own attempts to save a buck.
Just sayin'. Dealership prices aren't wholly unreasonable, there are reasons for them. It's mostly normal retail markup, 200%++ on little $5 stuff, 100% on most things, and at least where I work, big things like those $5000 transmissions actually have very little markup, <10% for example.
$30-$40 oil changes (depending on oil quality) have no profit margin; they're a convenience and a loss leader to bring in the other business that does pay. $800 for a compressor can be arrived at very easily; $250 marked up to $500, maybe 2 hours labor @$100/hr for the R&R, and another $100 for the a/c evacuation and recharge, and there you go.
