1 - 11 of 11 Posts
2004 gmc envoy_sle_xl
Heya fellas, I have an '04 Envoy XL with a chonky 203k miles, and the A/C has gone bad. Tried to recharge it with a couple cans of R134A and it seems to hold it in, but the compressor clutch won't engage to send the refrigerant through the system.
Am I dealing with a bad compressor? Would this be remedied by replacing the compressor and accumulator or is there another issue I'm not aware of? Thanks in advance!
I tried to get the compressor to engage by pressurizing the system with some refrigerant, but it still wouldn't kick on. I also did already try resetting that relay, and the fuse was still good. I'll try jumping that relay sometime this week though!
Probably just gonna end up buying a cheapo a/c repair kit off fleabay that comes with the compressor, oil, and expansion valve. Can get the gauges to vacuum and recharge the system for pretty cheapo too.
Check the low pressure switch mounted on the receiver/drier. I've had two go bad on my 2002 and even a licensed A/C shop missed it as the issue. Pull the wire connector and and use a small paperclip or wire to jumper the terminals inside the wire connector. If your compressor engages, you found the problem. its a quick cheap fix to replace it and doesn't require you to open up they system.
Good Luck
Discussion Starter #6
Good Luck
I'll take a peek at that here soon, thanks for the info!
2004 gmc envoy_slt_xl
I had the same issue a year ago and it ended up being the clutch. I went to the junkyard and pulled just a clutch from one for $10 just to try it. My old one was burnt and just not engaging. The good thing was it only cost me $10 and didn't have to open the system. These are very easy to replace also, the only "special" tool you need is a set of snap ring pliers.
2003 chevy trailblazer_ltz
Yep, when this happened to my '03, the clutch wouldn't pull in (engage) by itself--but if I whacked it with a broom-handle, it would hold engagement until I shut it off.
I was told that clutches are not available separately, so it would need a complete replacement compressor 'n' dryer.
The AC hasn't been as cool ever since. (but it does work.)
Consider just re-setting the clutch air-gap. Might be all it needs.
2009 chevy trailblazer_lt
Thegrimtaho:
Did you have an intermittent AC problem or did it fail all at once and never came back?
The paperclip trick should rule out the state of charge although a couple of cans should have been enough to get the compressor to snap on. If there is a leak big enough that the compressor did not engage, I would think a leak would be noticeable.
If everything else was working fine and the problem was not a complete cut out, as in it worked sometimes - it sounds like it may be the clutch. Did you try other calls for AC like Defrost and Recirculate? It could rule out some weird electric switch problem.
...And I know AC repair calls for the replacement of the dryer and orifice tube when the system is opened but if the compressor did not fail - only the clutch, and the system was not open for weeks or suffered from other contamination, I would not worry about replacing those parts.
This is great news....DETAILS PLEASE!!!!!
I am 99% sure my AC is fine except for the compressor clutch. I looked at replacing the compressor and it looks like the compressor will not come off the truck - ya got to remove the truck from the compressor! So your idea sounds like relative pleasure.
1 - 11 of 11 Posts
