1 - 12 of 12 Posts
Fuse was replaced with no luck. The light for 2wd 4auto 4hi & 4low does not light up when switching. I used 4X4 lightly last week to clime a small sand hill on a two track didnt really need 4X4 but didnt want to get stuck in Norther lower Michigan. The truck has never been beat, we bought it new 2002 has 161K miles with little or no problems except at 102K the ignition wiring needed cleaning per GM service bulletin ,service shop charged me over $700 claimed it was the computor. Stay away from Flecthers in Tucson AZ the one on Valencia anyway. Any help would be great. Thanks Don[616]745-4430 [email protected]
do you get a light saying service 4WD? my light comes on rarely i called stealership and they said it might be the switch
Moved to proper 4X4 drivetrain forum.
2002 models had possibly flaky TCCM (transfer case control module) that would fail to wake up with the ignition. A flaky switch could cause the wrong mode to be selected, but not a total lack of lights on the switch. There was also a change to the PCM software to help the module wake up. So you could have both problems, and only a dealer can flash your PCM with the updated software.
You could try swapping TCCMs (run a search here on trailvoy and read up on other member's problems and the module location) with a local friend if you can find one with a newer model trailvoy. Or buy one on Ebay. You may also need to find a trustworthy dealer to load the new software.
The service 4 X 4 light has not come on except when starting as it should. I just noticed one day last week the light for 2wd was not on as it normally was. I tried switching to see if just the one light was out but none would light up. Like I said I replaced the fuse and that did nothing for it either,I guess I will try to see if there is power to the switch and go from there. Thanks all,Don[616]745-4430
The switch doesn't have "power" in the way you might be thinking. The indicator lamp part of the switch has discrete wires, one for each lamp, right from the TCCM. So if none of the lamps is lit, it's the TCCM that's gone to sleep, or not woken up at ignition start, like it's supposed to. That's a dealer kind of problem to solve.
The mode selector part of the switch is like a potentiometer, where the switch selects a particular resistance, the TCCM reads that like an ohmmeter would, and the TCCM infers what position the switch is in by the resistance it sees.
Without the schematic and theory of operation from the service manual, just looking at the back of the switch won't be very illuminating, I'm sorry to report.
2003 gmc envoy_slt_xl
Hey, new member here, came looking to diagnose this same problem. Wife's Envoy has the same issue. No indicator at the switch, and no service 4wd light on the dash. No luck with engaging 4x4 either.
I haven't tried pulling and replacing fuses, that will be first on my list.
Agreed. Check the main fuse #8 under the hood first. If OK, the TCCM might be having problems waking up, especially 2002-2003 units. In that case, turn the ignition to RUN to wake the vehicle up, THEN pull, then reinsert fuse #8 after ten seconds to reset the TCCM. If the switch indicator lights come on then, then you have the sleepy TCCM syndrome.
For fun also, try to put the system into NEUTRAL mode. Check the Owner's Manual if you don't do this often. The NEUTRAL lamp is run off a different circuit than the other mode lights, in case it's a lamp issue instead of a TCCM problem.
Also check fuse #48 under the rear seat - it runs the front axle actuator, which if it fails will also disable the TCCM and make it give up.
Hey Roadie,
For a "sleepy" TCCM, do the switch indicator lights HAVE to be off? I'm going to try the fuse pull trick this afternoon.
My switch lights up just fine, and I can hear the TC engage in every position, but my front axle never engages. I'm sure it is a front axle actuator problem. Would a "sleepy TCCM be able to engage the TC but not the front actuator? Or do I need to replace the actuator, or possibly rehab it like you and Alex did a while back?
No. It would ignore any switch inputs. If you have a meter, you can try to diagnose the actuator more closely, but just see if it EVER tries to do its job. If you pull front fuse 8 to reset the TCCM, it should at least TRY to move the front axle actuator on the next attempt. If it fails to see the expected feedback, it should flash the light (like A4WD) on the mode you were trying to go into.
Remember, the front axle actuator is only ASKED to engage or disengage on the two transitions 2WD->A4WD and A4WD->2WD. Not on the other ones.
If rear fuse 48 is blown, it would disable the front axle actuator AND the "Neutral" indicator, while the other four mode lights would still work (even if they blinked)
If you hear the front axle actuator make noises on 2WD->A4WD and A4WD->2WD transitions, but the front axle doesn't physically engage, then you probably have the dreaded no-grease-splined-disconnect issue that's been plaguing more and more people lately.
Okay.
So, if I pull the front #8 fuse to reset the TCCM, and turn my switch to A4WD...will the front actuator try to engage immediately, or will it wait until it detects slip? I guess what I'm asking is....can I test this in my driveway, or do I need to be in slippery conditions (or with my back wheels jacked up in the air?)?
You can do it in the driveway with the engine off, even - to better hear the actuator and encoder motor.
Remember how it works. The actuator engages the front axle with a 2WD->A4WD mode change. The encoder motor ALSO moves to get the transfer case clutches READY and in position to transfer torque if it detects wheel slippage. But the encoder motor moves a bit to be ready, and makes a distinctive noise, lower pitched (larger motor) than the actuator.
When you change from A4WD->4HI, the encoder motor moves a bit more to fully engage the clutches. THIS movement is similar to what it does if it detects wheel slippage. But the high-pitched whine of the front axle actuator isn't present on an A4WD->4HI transition because it's already engaged. (If it's working, that is.)
Everybody should try this in their driveways TODAY. In case the system fails later, you need to know what it sounds like then it's working. Much faster troubleshooting than taking it to a tech tool for $$$ diagnostics.
1 - 12 of 12 Posts
