1 - 7 of 7 Posts
2006 gmc envoy_sle
Hello all,
I know this subject has been covered so much but I still cannot find an answer, so here goes with a little history of my problem.
I got the vehicle about 18 months ago and I now have my 4th bad Encoder Motor.
1st (Within the first 2 months of having the vehicle): The fist one shorted out when shifting out of 4x4 during a snow storm but my front diff never disengaged and that's when I knew I had an issue. I got a junkyard motor and confirmed the old one was bad. About 1 month after the motor had died.
2nd (Same time frame): The junkyard one, while installing, shorted out per the mechanic that installed the 3rd one.
3rd (At the beginning of the 2017/18 winter): Used it maybe once or twice before and then that one shorted out. Mechanic said he fixed the short and it should be fine. Now on the 4th one roughly 8 months later
4th (Used multiple times since it was installed in mud and other mild terrain): This one lasted for quite some time until about 2 weeks ago when I needed it for something besides going off road and snow and it failed again on me.
I have just come in from doing the "go to fix" buy disconnecting the battery for 30 minutes and pulling fuse 8 from the front fuse box and 48 from the rear. Nothing improved, I am still in Auto 4x4. The only noises I hear when trying to sift to any other configuration is the relays. I'm not sure if this could be a coincidence or not but the day prior to this Encoder failing I replaced both my front hubs with MOOGs. Also other ongoing issues would be a P1682 code which when it trips it turns my 4x4 maintenance light on and turns my TC off. And lastly the Encoder always seems to fail in the cold New England weather.
Any input from anyone else who has had the same or similar issue would be greatly appreciated. I am beyond frustrated and I cannot seem to trace this issue and I am tired of throwing money at the same part over and over again. I will be testing the motor off of the transfer case tomorrow 12/8/18 and if indeed the motor is completely bad again I have another one lined up for $40 that has been tested and proved to be working.
Have identified the short? I’m currently having the same issue not sure if just a bad motor or there’s something else at play
2008 chevy trailblazer_ls
4X4 not working
Hello All,
I have a similar problem with my 4WD not working. Crazy thing is I parked the truck in my garage one day and didn't drive it for a couple days. When I got back in and started it the following lights came on:
Service Drivetrain
Check Engine
ABS light
None of which were on when it was parked.
I have replaced the dash switch, both front and rear actuators and encoder, and I popped a working TCCM module in place of my original. Nothing fixed the problem. I can hear the encoder motor under the driver's seat when I attempt to put it in 4 wheel but I hear nothing from the front actuator. The front was a Dorman. I don't remember the brand of the rear actuator/encoder but it seems to be working. Has anyone heard of the Dorman front actuator not working? I have had many troubles with this truck and I'm fed up with it. Already had to replace ignition switch, blower resistor pak (twice), steering wheel position sensor, and the exhaust manifold cracked at 40,000 miles. No more GM anything for me.
Thanks in advance for any help!
Dorman electrical products are not known to be reliable. If your disconnect actuator is not operating and you have changed TCCMs (and assuming that the Dorman part is OK), there must be a wiring issue at play.
Re Throwing an idea to look for with the electrical motor burn out
Hello all,
I am new to these forums, but not new to GM's SUV line and not new to turning wrenches on a lot of makes and models of vehicles, personal and commercial. I came to the forum today for a separate transmission issue, but came across this thread. Here is a thought to at least look at, just to rule it out or find any issues with it:
On a Ford Bronco II that I owned at one point, the four wheel drive got stuck on and I could not get it disengaged. I was told by my neighbor of the time that the issue was a vacuum switch on the transfer case. After changing that out, the four wheel drive instantly disengaged and the truck ran fine.
Since motor after motor keeps burning out, then there is a separate mechanical problem and not the electrical actuator motor. At least look in to the vacuum switch on the transfer case, as it is, at minimum, suspect.
Good luck!
2004 chevy trailblazer_ls_ext
I don't have anything to add that may aid in diagnosing and fixing this issue (other than don't use Dorman electrical parts), but I have always felt that A4WD is a bad idea! The constant switching in and out of 4WD is going to cause a lot of wear on those parts. If you need 4WD, select 4HI or 4LO (depending on conditions) and then stay there until conditions permit switching back to 2WD.
Just my humble opinion, and you make take it for what it's worth.
Irishrockdoc - just to let you know there is no vacuum involved for the transfer case on this platform.
I agree if there are multiple failures of the disconnect actuator, there maybe a mechanical problem with the disconnect itself.
1 - 7 of 7 Posts
