Good morning all,
I have a 2007 4X4 Trailblazer with 97,000 miles. Recently I have noticed a clunk or possible slip when in 4x4 HI or A4x4 only when going up a long steep hill. I can hear the actuator in the transfer case switch when I move the dial for all 4x4 positions. Once and a while I will also get the service 4x4 light but as soon as I turn the key off it clears. I have changed the T case fluid and front diff fluid. I know the 4x4 is engaging because I tired the same hill in 2wd and had to pull over to switch to 4x4 to make it up. I have read in other threads about the front axle disconnect. Does this seem like it would be the problem? I don't want to throw a lot of money at this thing unless I know it will fix the problem.
Thanks in advance
I have the same noise in the same 4*4 modes but only when making a turn . 312,000 miles / 2002 LTZ
These are some of the best SUV'S on the planet .
2006 Chevrolet Trailblazer LS 4.2L l4
I have an ‘06 with 228,xxx miles, had a service 4wd light come on, and the light would blink for a few seconds before finally switching to 4HI/A4WD, so I had my shop check transfer case fluid when we had it in the air for an oil change. T case was almost empty, added almost 2 full quarts (2 qt capacity), and when we pulled it out we ran it through all the gears to see if it fixed the issues, and the t case got stuck in neutral. Our tech supervisor told me the encoder motors like to go bad, so i pulled one from the scrap yard, switched that with what i’m assuming was my OE motor, and haven’t had any issues since.
Why Why Why do people drive in 4WD on pavement or complain about it malfunctioning when they turn?
Unless you are on ice/snow/mus/zombie bodies/--- drive in 2WD HI unless you really need to go 4WD.
As far as I have learned , A4WD is nasty to the transfer case viscous clutch assy and it is very expensive to repair.
