1 - 6 of 6 Posts
My 2002 trailblazer has been switching itself into 4WD on its own. The first time I've noticed this happening was when I was taking a sharp right at a light into a gas station then took a sharp left up to a pump. It was hard to move taking the turn pulling in and then even harder pulling up to the pump, that's when I noticed there was something wrong with the 4WD selector switch. Multiple modes were lit up or blinking. I turned the switch to 2HI and my truck jerked around but then seemed fine after that. The same thing has happened a few times after that. I have noticed it at a high speed before but I'm not sure if it switched over while at high speeds or not. Each time it happens I stop, put it in neutral, move the switch out of the 2HI position then back into 2HI and then its fine again. Last time I drove it the "service 4WD" light came on.
I'm trying not to drive it right now unless I have to. I'm starting a new job soon and will have to drive then so I hope to fix it before then. I'm going to be doing all the work myself. I was thinking I'll start with replacing the selector switch then swapping out the transfer case control module. Before I do anything I figured it would be a good idea to post this thread first to see if anyone else had a better idea of what could be causing this problem. I'm also very low on cash and can't afford to put a lot of money into it without fixing the problem. Once I find the solution I plan to report back to this thread.
If anyone has had this problem before, I would appreciate some advice. Thank you.
The 2002's had a problem with the TCCM going stupid sometimes. If you replace it, get one from a 2003+ truck.
Before changing anything, try rotating the 4WD selector switch thru all of it's positions multiple times while truck is off. The contacts sometimes get dirty.
got tccm
I'm going to be putting in a TCCM tomorrow. I believe was out of a 2007 trailblazer. The part number is 24233673. Really hoping this works.
Discussion Starter #4 (Edited)
the new TCCM seemed to work fine with no problems for a couple weeks but now the light on the switch blinks on startup then goes out completely and a red N is lit up on switch. sames thing happens trying to switch modes too, just blinks then goes out.
still not fixed
I tried removing and reconnecting the tccm and selector switch and making sure the connections were good but nothing changed. I also tried switching back to the old tccm just to see if the if the old problem came back but it's doing the same thing using both tccms now. I don't hear it trying to engage at all with this problem so i guess I'll probably try replacing the encoder motor next.
Discussion Starter #6 (Edited)
I'm still at a loss. I'm still thinking about replacing the encoder motor but don't want to spend the money for it not to work and I don't think I'm supposed to do it while its still in 4WD.
1 - 6 of 6 Posts
