gmc
If you have had to replace your 4200 I'd like to ask the following and please indicate it in your reply:
1) year of engine
2) what failed e.g. rod bearing/rod knock
3) what caused the failure if known: e.g. overheat or ran out of oil...
4) how many miles on engine when it broke
5) year of engine you used as a replacement
Thanks
My baby was victim to the bad batch of cylinder liners early in the '02 model year production. I was lucky enough to NOT have the engine grenade and left stranded and merely had what almost sounded like a rod knock or collapsed lifter. (While cracked it didn't slide completely down the cylinder bore). GM swapped the engine with an '03 block with the upgraded internals at the 16-18k mark.
I was ready to trade it before it came back, but this was the VERY first time that a major repair like this was done to my satisfaction. It took something like 7-8 working days, but every wire, connector and fastener is the same as when it left the factory. I went over it before accepting it back and was amazed at the job the GMC dealer did.
Haven't had any other powertrain issues to date, knock on wood.
2008 isuzu ascender
engine
I havent read where there has been a problem and people routinely get 200K or more out of them . Maybe the first couple of years they had a problem but that was 10 years ago.Maybe a google search would reveal more.
2008 gmc envoy_slt
I had the engine replaced in my 08 Envoy at 77K. It started with a cracked exhaust manifold which led to broken bolts (by dealership) which led to a fouled head (while drilling out the bolts) which led to broken head bolts (by dealership) which led to a fouled CPAS which led to a fouled block which led to a complete engine replacement. Good thing I was still under the power train warranty.
2008 isuzu ascender
The cracked manifold is a issue but the rest is not an engine failure if the dealer is dropping metal shavings into the block while trying to fix it .
