2009 envoy binds up in revers when in 4 wd when you turn
There isn't anything wrong. Your driving your truck wrong.how can you check for what might be wrong
He said it did it while driving in snow. That's not wrong.There isn't anything wrong. Your driving your truck wrong.
It says in the initial post that he was turning. He also said it does it on dry pavement. That would indicate to me that there wasn't enough slip/snow to allow the 4 wheels to operate at different speeds, which is what happens when you turn with 4wd.He said it did it while driving in snow. That's not wrong.
It is working perfectly as it should and it does that binding from the factory. Don't turn on 4wd unless there is snow. And don't use it while taking tight turns.this is my first 4 wd would like to know how to make sure my stuf is working like it is suppose to
