1 - 9 of 9 Posts
2002 chevy
EDIT: I meant to say I have a 4.2L I6 Engine.
I am looking at a possible good deal. There is a shop near me that my father-in-law knows the owner. Well in the shop they have a v8 motor from a newer model suburban probably around 2004+ I believe it is a 5.3L v8. I am wondering to the best of your knowledge would that motor be able to go into and replace my 4.2L Inline 6? Just curious, I know you may need to know more info. But if there is anything I need to look for, aka engine codes written somewhere on the motor, etc let me know what I need to look for.
Thanks
D~
2007 chevy trailblazer_lt
4.2l v6?
Its a bolt in swap use the same mounts and wire harness they are identical on the v6 and 5.3 v8 both engines. The only one that is not a bolt in is when you have a 4.2 I6 then its not worth it for the swap because everything is different.
2002 chevy
Sorry typo on my part. It is 4.2L I6
Swap in progress
I'm starting to swap the 4.2 to the 5.3 this weekend any and all info will be taken into considertion, already have a 2004 5.3 from a silverado done the transmission research it will bolt right up my only issue as i sit is the wiring harness but i am looking into splicing a 5.3 wiring harness with PCM with a 4.2
2002 olds bravada
Your other issue you are soon to realize is the I6 has the trans crossmember welded in at a different spot. Yes, you can definitely cut it out and weld it back in or weld another in.
2007 gmc trailblazer_ls
going necro on this with a bump. i found some 5.3's being parted out, have plasma cutter, welder, and energy drinks. has nobody pioneered this? i've searched for hours and not found a single soul claiming to have done it, and it'd seem to be a trivial swap (relative to other swaps).
2008 chevy trailblazer_lt
In 2015 when I really wanted a v8 short wheelbase trailblazer, I just set up automatic searches with a wide radius on all the used car sites until I found one that was real nice. It was a 6 hour drive to get it but it's now the longest vehicle i've ever owned.... times wise, not inches wise :p
1 - 9 of 9 Posts
