Yes you would and should disconnect the battery ,but I would try cleaning it real good and ;put it back on an try it 1st!
Thanks, Loverotties... I have cleaned it myself and had it professionally cleaned, but the problem was actually diagnosed as a fault in the interior wiring of the throttle body.Yes you would and should disconnect the battery ,but I would try cleaning it real good and ;put it back on an try it 1st!
Agreed...price is way high......That price seems a little high check online maybe rockauto and put it in yourself
Thanks, petevw... did you find the TB under the 4.2L or 5.3L or is there no difference between the two. I have a 4.2L and want to be sure that whatever I get works.Agreed...price is way high.
RockAuto has it for $251 plus shipping, but you can also use the 5% off discount code (current code #79531553023843 is good until tomorrow 3/4/12)
That was the price for the 4.2.Thanks, petevw... did you find the TB under the 4.2L or 5.3L or is there no difference between the two. I have a 4.2L and want to be sure that whatever I get works.![]()
