21 - 24 of 24 Posts
GM# 15000045 Avalanche Brake Lights
See Ebay Auction# 200194938109 for GM# 15000045 Avalanche Brake Lights Neon $24.99 New in box
Hi Larry,
There are only two screws that hold the fixture in place. Once you remove them, the fixture will push out. It is a tight fit though so you need to push it out from the side that the lense is on.
If you want to reduce your labor, you can just cut the wire going into the brake light right at the fixture and then strip the ends and solder them to the LED strip. You may want to put a connector on instead so that you don't have to solder it in place.
I actually removed the Brake light fixture along with the wire, but to do this requires that you pull back the ceiling gasket in the back and pop a couple of fasteners that hold the ceiling in place so that you can unplug it. There is also a grommet that needs to be pushed through to remove the wire and connector along with the brake fixture. It's not worth the effort.
Good luck,
Mark..
Thanks for all the help.
Does anyone have an original 02 or 03 light and housing hanging around they need to dump/??
21 - 24 of 24 Posts
