1 - 9 of 9 Posts
2002 Pewter ls with automatic trans. 4x2, gray cloth interior.
Anyone know of a good rocker switch and a spot to mount it? I have aftermarket fogs and wiring harness with horrible unmounted switch.
*10/18/21 Do the switches have to be rated the same as the wiring harness?
My wiring harness specs are:
  • 12 v / 30A Relay
  • 15A Fuse
Likely any auto parts store will have the rocker switch.
As far as where to mount, I do not have a clue.
Good Luck
  • Like
Reactions: 2002 TB LS
  • 12 v / 30A Relay
  • 15A Fuse
Will a 12V 20 Amp Toggle Rocker Switch work?
First, you have to realize that if something is going to fail, y (say a hot wire shorting to ground) you want to minimize any potential damage to the lights and to the vehicle's electrical system. Hence, when looking at the various device specifications, fuse - 15 Amps, Relay - 30 Amps, and Switch - 20 Amps. The fuse is your sacrificial part and should blow in the event of either a short or the lights pulling more than 15 amps. So yes, you can use a switch rated at 12 V and 20 Amps in your fog lights installation.
If you were to run a lower amp rated switch, you risk the switch overheating and the potential for it to cause some damage, including an elevated risk of fire.
  • Like
Thanks for clearing that up! Going to look for a nice 3 gang switch and panel.
Good Luck!
  • Like
I love relays!
That said - I would always use the switch to signal the relay to do the (any) heavy lifting ... all of this is fused, natch!
I love relays!
Wouldn't a relay be powered by the fuse box? I like to be able to just have an independent switch for the lights.
Even a simple wiring harness with a switch is hard to find.
Theres nothing bad nor inherently evil about putting your own relay and circuit in a light wiring system.
No way I'd want to even consider using the vehicle's own relay circuit board!..
1 - 9 of 9 Posts
