1 - 12 of 12 Posts
2008 chevy trailblazer_lt
I am going to be selling my original tires from my TB in a few weeks, they only have 1200 miles on them. Not sure how much the price would be yet but if you are interested let me know.
Discussion Starter #5
search the forums...just warning you b4 the pack comes lol
what makes you think i did not check already? thanks for the warning but i know how things go on most forums and i tried searched and didnt come up with what i was looking for.
http://forums.trailvoy.com/search.php?searchid=2017728
if you find it there please tell me. i found info on 255/70 17, 255/65 17, 255/55 17
im 99% sure it will work because all of the above have worked with no problem minus the 255/70 17(worked with slight grinding to upper control arm) but i guess i just wanted someone with more expertise with tire sizing then i do to chime in. maybe a picture or two would help?
Discussion Starter #6
thanks for asking but im looking to order tires within the next day or two. GL with the sale though!
2004 chevy trailblazer_ls_ext
If your stock size is 245/65-17 then the 255/60-17 would be:
- .4" shorter in height
- roughly a 1/2" wider
2008 chevy
TBSS which sits 1" lower comes with 255/50R20 which dimensionally is nearly identical dimensions to the 255/65R17, and 265/50R20 fits so you should be more than ok with that size.
i've been running 255/60/R17 for over 4 years now. With no issues. The speedo will be a little off since the tire is slightly smaller in diameter, but barely noticeable.
2009 chevy trailblazer_lt
255/60r17
The TB tires specs in middle east gulf countries are 255/60R17. I have been driving on those for more than 8 years. The speedo will be below actual speed but it would be more stable.
2008 gmc envoy_denali
Thanks for adding to the thread but you need to check the dates when looking thru the sections. This one is 9 years old... Just so you are aware. :)
Mark
255/60r17
Thanks Mark.
I know. I still benefit from posts who are even older than this. I thought I could add something :)
1 - 12 of 12 Posts
